Memory Upgrade Question, Please Help
HansG
36
I want to do a 2 GB memory upgrade and need the memory to be 184 pin, CL:3 unbuffered, non-ecc, 400DDR, and PC3200. I went to Newegg.com but a lot of their memory doesn't say wether or not it is non-ecc which is what I need or so I'm told anyways. Also a lot of their memory doesn't say if it's unbuffered which is what I need also. Any way to tell? I don't want to take the chance of ordering the wrong memory.
Sincerely,
Hans
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Go to the memory manuf. sites themselves and use their configurators for your MB. Then, armed with the part numbers, go back to NewEgg and order. We all have our oppinions on what's the best memory or value but, it's good to do your own footwork and be sure to check the memory sites for any problems other users have had with memory and your specific MB.
