Memory timings - too confusing - can anyone help?
cmf21
Putting together a new system. Everything is running fine. Had to find and correct the memory speed in the bios but I need to do the timings now and there are so many stinking options that I'm totally lost and don't know which ones need to be adjusted.
Motherboard is Asus P6X58D-E
Memory is Corsais CMX6GX3M3C1600C7 7-8-7-20
Going to take a screen shot of CPU-Z in a bit but which of these do I need to adjust? Too many darn settings.
Here are the settings from the manual. Too many to choose and change.
Set them to "Auto", it won't make any real world difference.
It's like tweaking a 56k modem to connect at 43k instead of 38k.
yup - memtest is built into win7 now - prime95 too- you might stretch 1-2% performance for risk of stability - you can make that up using other methods (more ram; tweaking o/s; overclocking).
honestly i just take the hit with ecc ram these days; my win7 boxens with 8gb of ecc (ddr2/ddr3) never crash. the non-ecc cpu/boards have their days sometimes. who knows whats going on because a non-ecc cpu with a non-ecc ram and non-ecc bus (PCI-E) has no way of detecting faults (and correcting).
xeon's run ecc to the bus, to the ram, internally. its a good thing 😉
My suggestion is to enter the BIOS and enable the XMP profile. This will set all the memory timings and voltage correctly for you. If you, want, take a good look at the BIOS before and after and you can compare and see what has been changed.
