Originally posted by: Oyeve
I doubt it. I have 2 sticks of 512meg pc3200 for 1 gig and I popped in 2 more sticks of 128meg pc3200 and my system went from 400mhz down to 320mhz because the timings were different in the 2 128 pc3200 sticks. I havent been able to fix it yet so I just live with 1gig.
I think that is more because most mobos can't really handle all 4 DIMMs being filled, so they have to scale the RAM down a bit.
Also, in theory, the RAM should just scale the timings the same as the slowest one. Have you tried each stick individualy in all the different slots?
Originally posted by: XooooX
Ok i have both sticks in and it boots up into windows, however its only reading as 512 not 1G, like its not recognizing one of the DIMMs.....
Ok, one stick is OCZ 3200 Rev2 rated at 2 CAS in cpuz, the next is OCZ 3200 Rev3 rated at 2.5 CAS.Originally posted by: Viper96720
motherboard? use cpu-z check the timings of each stick individually. Put 1 in boot up check the timings then check the other. Set bios to the slower timings. Since if one stick has tighter timings it should be able to run the slower one as well.
Use cas 2.5 if one is cas 2 and the other is 2.5. What about the other timings? ras to cas delay, ras precharge, tras, trc.
Just set in bios...Originally posted by: JustAnAverageGuy
set them both to 2.5-3-3-6 then 🙂
Try DRAM Frequency 200Mhz
cas 2.5
Trcd 3
Tras 10
Trp 3
leave rest auti
