Memory timing help
cich1012
58
Below is what my rig consist of. Below that is what I have my system clocked at I was wondering with that configuration what should by memory timings be set at such as the cas. trc? you know all those settings in the memory section of the bios. Is there a specific list I could put them at cause I only know a few to change such as the standard ones.
Asus a8n-sli premium MOBO with cool pipe technology.
1024 OCZ ram 2-3-2-6 OCZ4001024ELDC-K
AMD 63 3500 cpu (Venice) CLOCKED AT 2.706 MGHZ 32C idle
2 x BFG 7800 GTX
Maxtor 120 gig 7200 rpm 8mb buffer
Audigy 2
Danger Den WATER COOLED
On the CPU/Dram config page
HT multi = 3x
Max mem clock = DDR333
Cool n' Quite = disable
On the jumperfree page
HTT = 246
Cpu multi = 11
Cpu volts = 1.55v
DDR volts = 2.8v
PCI clock = 33.33
