memory that will do 2-2-2 at 500 mhz?
hmmzzz
35
I'm going crazy to be honest, im looking for memory that will do 2-2-2 at 500 mhz...
Prefferably at 2.8 volts...I know its out there, but im not sure what to choose, all these different chips, bh 5 , ch 5 , bh 6, winbond, utt (<which is not a chip ?)...
Anyone here has some knowledge about that? Dumb question, that last one, but some insight would be appreciated...
hmmzzz
35
No, so only at higher voltages ?
What i meant was memory that is likely to do 500 mhz with 2 2 2 timings....
OCZ platinum 3200 for instance..? Will that do those timings at that speed?
Sonic587
1,146
Why not look into getting the OCZ DDR Booster and grab some of the brands highlighted in this review? I may be wrong, I don't think there is any RAM out there that will do what you need it to without the extra juice.
Also, why isn't your current RAM fine? Timings don't make that big of a difference in terms of performance anyway.
hmmzzz
35
Well, this memory indeed does 500 mhz, at 1T, but the timings are terrible...3-4-4-8...I have this retarded bench adiction and 2-2-2 timings would make quite a difference i think...
(reading link)
Sonic587
1,146
Have a look at this post....IMO, save your money. Upgrading your CPU or videocard would probably yield better results than getting tighter timings.
