Memory Stick/Pro Duo reader compatibility
zagood
Copied this from Peripherals, no responses there.
Just recently found the need for a MS Pro Duo reader, and dug out an old 6 in 1 card reader from an HP. It has a slot on it labeled "Memory Stick" but I'm wondering if this will support the Pro Duo as well. On the HP site is lists "Memory Stick, Memory Stick Pro." Also wondering about Vista Business x64 compatibility. p/n 5187-2500 rev D-A23
http://h10025.www1.hp.com/ewfr...lc=en&docname=bph07910
I'm asking before testing it myself because I can't find the internal cable, and would like to have an idea before ripping apart my wire box trying to find one.
If it's not compatible with what I've layed out, any suggestions? Mainly looking for internal 3.5". Color doesn't matter as I'll be using vinyl die to match the white of my P150.
Thanks!
-z
