Memory Stick/Pro Duo reader compatibility
zagood
4,102
Howdy.
Just recently found the need for a MS Pro Duo reader, and dug out an old 6 in 1 card reader from an HP. It has a slot on it labeled "Memory Stick" but I'm wondering if this will support the Pro Duo as well. On the HP site is lists "Memory Stick, Memory Stick Pro." Also wondering about Vista x64 compatibility. I'm not home right now so don't have the part number onhand. It came with the a230n and I'm pretty sure it's this one:
Text
EDIT: p/n 5187-2500 rev D-A23
I'm asking before testing it myself because I can't find the internal cable, and would like to have an idea before ripping apart my wire box trying to find one.
If it's not compatible with what I've layed out, any suggestions? Mainly looking for internal 3.5". Color doesn't matter as I'll be using vinyl die to match the white of my P150.
Thanks!
-z
