Memory Stick Pro Duo Adapter to SD $2
Status
Not open for further replies.
tomatom
331
http://www.meritline.com/mcirosd-to...&hq_e=el&hq_m=1929496&hq_l=60&hq_v=f2568a7e70
Micro SDHC chip to Memory Stick , $2 free shipping
< I really like Sony Cameras , but NOT the Memory Stick >
PSP Memory Stick Pro Duo Adapter(MicroSD (TF) to MS Pro Duo) , Ideal for PSP, Sony Digital Camera & Mobile Phone
Manufacturer Part # 1
Features:
Support up to 8GB MicroSD/SDHC
Converting MicroSD to Memory Stick Pro Duo
Avoid the costly memory stick pro duo, replace it by bargain MicroSDHC
If you are a PSP lover, you definitely should have one.
Large capacity MicroSDHC can store more games, music and movie, rather than keep deleting files as the limited storage of expensive MS Pro Duo.
Additional Information:
The adapter can be used in most MS Pro Duo devices. If you can not format the memory card from your PSP, digital camera or mobile phone, please insert your memory card back to your computer and format it in appropriate format(FAT/FAT32, please read the user guide of your device for reference), then the adapter will work properly.
PuppettMaster001
1,651
4
I have this with 2x8GB micro sd cards in my PSP and it works great. Been using it for about 5 months with no problems whatsoever.
Status
