MRGOOCH Platinum Member Feb 6, 2004 2,292 0 76 Mar 14, 2004 #1 I have one stick of 256 mb. What slot should it be put into?
P Peter Elite Member Oct 15, 1999 9,640 1 0 Mar 14, 2004 #2 Since you didn't tell us which mainboard you are talking about, all I can do is suggest you read the mainboard's manual.
MRGOOCH Platinum Member Feb 6, 2004 2,292 0 76 Mar 14, 2004 #3 A7N8X Deluxe v2 The manual isn't that clear about.
I InlineFive Diamond Member Sep 20, 2003 9,599 2 0 Mar 14, 2004 #4 If it's not dual-channel it doesn't matter. Stick it in Slot 1. -Por
