I ran memtest for 4-5 hrs yesterday, and it passed all the passes (I think it was 8 passes, but I forget).
Lets say it does start to fail, what are some of the signs? Will it start corrupting data right away or does Windows (XP PRo) usually gives a warning like a bsod? I don't want to copy over corrupt data into another computer from this one in case that happens.
If you want, just test it overnight, and if you want to be thorough than in addition to memtest86+ (note the +) used MS's memory checker as well, and let it run overnight also, extended tests. Here is the win7 docs: http://windows.microsoft.com/en-us/w...-your-computer
As for what happens when it fails, it can be VERY hard to detect, since random things can happen. It might cause BSOD, it might corrupt something, and so on.
It just depends on what is using the defected part of the RAM chip, and there is just no way to know besides doing memory testing on it.
Both memtest86+ and MS's version don't care what OS, since they take over your machine at boot.I am using win xp pro, not sure if there are other ones besides memtest.
