- Jul 26, 2004
- 192
- 0
- 0
I recently had a stick of memory kick the bucket. I tried to find my system using the Newegg memory finder, but it is not listed. I want to both make sure that I get a stick that is compatible with my system, and also make sure I'm replacing the right stick.
With that in mind, I have an Asus CG5290 computer that shipped with 9 gigs of ram. It appears that the memory is available here, but I would prefer to buy from a reliable source like Newegg or Amazon or something where I am assured of a great return policy in the process, and I would like to get memory that has a warranty.
The stick that went bad appears to be one of the 3 2 gig sticks. The computer was triple channel, then a memory stick went bad, and right now it is dual channel and down 3 gigs. I didn't even know that was possible, but at the moment it seems that 2 of my 2 gig sticks are reporting as ordered, as are 2 of the working 3 1 gig sticks. Memtest reported memory in slots 0-4 (it used to report through 5). Does the memtest report accurately indicate in which slot each memory module is located, or do I have to run a test on every stick to find out which one I need to replace?
I know I need to look for DDR3 240 pin 10600, 10660, or 10666 memory. I am not 100% sure what CAS latency I need to find. I think it was 9 from previous memtests, but right now it is reporting as 8 and in dual channel mode. How can I be sure? Am I correct about all of this?
I would love some help with this and/or some suggestions on what memory in particular to buy. Should I just aim to replace the 1 stick, or is there any advantage in buying a set or anything like that? Does the brand need to match or am I ok if I simply match up the specs?
Thanks a bunch for your time.
