I recently purchased a 5930K as I'm building a new system. I don't have all the parts yet though, the only thing I have left to get is the RAM..
I'm not sure whether I should go with a 16GB kit, or a 32GB kit. Usually I'd say 16GB is enough for high end gaming, but next year's GPUs will have very large frame buffers (even more than Titan X for certain models), and I'm wondering whether 16GB of RAM will be enough to buffer next generation Pascal GPUs, which will reportedly have as much as 16GB of VRAM on their top end consumer GPU (Titan XI perhaps), and as much as 32GB on their professional GPUs.
Another thing I'm wondering is what speed RAM to get. If I get 32GB, I would likely want to get at least DDR4 3000 speed, as I'll probably have this new system until Cannonlake-E arrives in 2018 or so..
If I opt for DDR4 3200 instead, then it would have to be 16GB because I don't think any manufacturer makes 32GB quad channel kits at that speed.
But from my reading, it seems as though Haswell-E has problems with high DDR4 speeds unlike Skylake, so I may not even get a chance to take advantage of the RAM speed..
