Memory problems --- thought GEIL was good
JustAnAverageGuy
9,057
memtest.
The regular GeIL stuff AFAIK was known to have quite a few bad sticks.
They love the extra voltage though ;)
pcman83
397
I have heard that giel will not run right unless you bump up the voltage to 2.7volts. See if you can do that, and what is your motherboard.
good luck
dunkster
1,473
If your memory settings are stable, then raising Vcore should get you Prime-stable.
Apr 17, 2003
37,622
bump the memory voltage
btw, geils high end stuff (like the platinum series) is good, their value stuff is crap
