- Jul 6, 2003
- 1
- 0
- 0
Hello guys...
I`m having a problem with my Epox 8RDA motherboard. It simply can`t run any memories at their default speeds. What happens is that, for example, when I use my 256mb. DDR400 Elixir stick at its default settings (400, 8-3-3-3 @ 2,7V.) Windows XP wouldn`t even boot. At 333mhz. It`s a little bit more stable, but reboots in Windows are constant. It is only completely stable at 266mhz.
I`ve already tried a SpecTek 512mb. DDR333, but the problems are just the same. It isn`t, either a problem with the overclock on the CPU, because with the CPU at its defaults, the problems are the same.
I have the latest BIOS from the Epox website and my specs are:
Athlon XP 1700+@2100MHZ. (200X10,5)
ATI Radeon 8500 LELE@310/260
Quantum Plus AS 20gb.
CD Burner
DVD rom drive
Troni ATX 450w. Power Supply
Are these memory sticks incompatible with my MoBo?!
Thanks for any help...
CD Burner
DVD rom drive
