Memory problems, blue screens galore.
Nocturnal
18,927
I have an A8N32-SLI Deluxe with recent BIOS and an 3800 X2 Manchester with 2GB Crucial Ballistix Tracer.
Anyhow I've been having blue screens lately and I finally got around to testing the system using Orthos Beta by Johnny and soon realized that at stock settings, including CPU and memory that I had errors. I realized then that perhaps there is something wrong with my memory.
I ran Memtest on my computer for 24 hours and there were no errors reported.
I went ahead and overclocked my system by changing the FSB to 210 and leaving the multi at 10. As soon as I started the Orthos program not even a few seconds in I got an error.
I tried with one stick in instead of both. Each stick could go through with the system overclocked to 210x10 with no errors for around 5 minutes.
I immediately put the sticks back in and tried Orthos again and again it failed within a few seconds.
I went back into BIOS and upped the DDR voltage to 2.75 for my Ballistix sticks and now I am error free in Orthos.
Should I have to up the voltage to 2.75 (I know Ballistix is rated to run at 2.8)? Shouldn't auto be fine or no? Are some memory sticks/brands picky about this particular setting?
UPDATE: Even at 2.75 it error within Orthos again. I put it back to stock everything except for the 2.75 DDR voltage. I'm about to try again. I'll report back.
UPDATE: Okay even at stock speeds with both DIMMs installed it errors. Does anyone think I can safely conclude that my memory is at fault? The thing is, if I put in one or the other and run the tests they don't error. Is that indicative of the motherboard possibly being bad? I won't know until tonight when I can take my box home to test out other things. This sucks.
Rubycon
Madame President
Aug 10, 2005
17,768
485
It could be voltage droop (as tech heads call it).
As long as the actual memory module stays within limits and the heatspreaders aren't boiling hot it should be fine.
A lot of enthusiast parts require more voltage to achieve top speed. DDR-2 spec is 1.8V yet some modules won't post until they get 2.0v. That's a PIA if you don't have standard module to get into the BIOS and set the voltage to 2.0 or higher.
Nocturnal
18,927
Just an update, I changed the the setting T1 to T2 and for some reason or another it's been stable on Orthos for 10 minutes. Hmmm.
