Dopekitten
Basically, my HDD crashed, so im trying to reinstall Vista/Windows 7. Here's the problem. It boots up, i select boot from CD-drive (which has my Vista boot disk in it), and it says Loading Resources or whatever, with the bar at the bottom. Once that is done, it goes into the Vista startup load bar--everybody is familiar, you know the loading screen before the login menu. It completes that, and then the next thing that should appear should look like this:
This what it should look like
However, i am stuck with just the background--without the window showing install now popping up. The mouse icon doesn't indicate working either. Now...at first i thought it was a bad CD drive, but i tested the disk on other computers, and it worked fine. So i was like whatever, ill just take the working CD drive and hook it up to my computer. But when i did that, i got the same problem. I replugged the "working" CD drive into the other computer, and it worked (like it had before). So i was like WTF, it means its localized to something in my computer, other than the CD drive.
I tested the RAM, i switched the places, took 1 out, and used only the other, and then switched them. Nothing worked. However, BIOS boots up fine. My HDD which im using now used to have XP, i reformated becuase whenever i tried to boot it would jsut say "error loading operating system."
Any idea on what could be the problem? I'm thinking motherboard, but i don't know for sure. Could it also be my CPU? i had it overclocked, but never above 1.3 volts (Q9450) so it was well within the specs for voltage.
I have a P5Q-E P45 motherboard and 4gb Corsair Dominators
Thanks
I posted this on Tomshardware--heres what i've done since then. I tested both ram sticks, isntallation never progresses with either one in (by themselves). I don't think the RAM is fail--i mean it posts
Also, i tested the IDE cable (i got a new one, so that works)
Could it be my motherboard?
Thanks
