Hi everyone and sorry for my bad english!
I got this strange problem which makes my system "weaker" that it should be. Here's my system info:
Asus A7V motherboard (Rev 1.02)
Overclocked Thunderbird 700MHz@850MHz (I've connected the L1 bridges)
Kingmax 128Mb 133MHz (Ver 1.02)
Asus V3400TNT 16Mb TV-in/out video card
Soundblaster 128
IBM Deskstar 20Gb
OS: Win98SE
BIOS settings:
System Performance: Optimal
DRAM Frequency: 133
CAS etc. speeds: 2-2-2
Vcore is set to 1.75 and VIO is on its default setting, 3.3. CPU temperature is about 50C, so its quite normal I think.
The main problem is that when I run the memory benchmark on Sisoft Sandra '99, it reports my memory speed is about 280. Normally and what I've seen on the net it should be something over 500! I have reinstalled Windows and installed the latest VIA 4-in-1 drivers but the results haven't got better. And the WCPUID says the system's external speed is about 200, shouldn't it be 266 since I have 133MHz memory. Correct me if I'm wrong.
What ever could be the problem?
Thanks in advance for your help
Soundblaster 128
IBM Deskstar 20Gb
OS: Win98SE
BIOS settings:
DRAM Frequency: 133
