Memory/Power Supply for my new rig?
AgeOfDiscovery
23
My new rig's coming in soon, tell me what you think :)
1. AMD Athlon 64 3000 (Winchester Core) - Socket 939 CPU
2. MSI K8T Neo2-F Via K8T800 Pro Chipset Motherboard Socket 939
3. 512 PC3200 Memory Kingmax 2.5 latency
4. 160 Gig 7200 rpm IDE Hard Drive
5. MSI Nvidia GeForce 6600GT - 128MB AGP Video Card
6. 2.4x DVD+R DL (Double Layer), 16x DVD+R, 4x DVD+RW, 8x VD-R, 4x DVD-RW, 48x 7. CD-R, 32x CD-RW
8. 16x DVD Rom Drive
9. 1.44 Floppy Drive
10. Raidmax Scorpio Case w/480W PS
The question is I want to get 1GB of ram, but what should I go for? I could sell the 512mb Kingmax and get some faster memory, or just upgrade 512mb more of the same type for cheap. Some memory I've been looking at:
http://www2.newegg.com/Product/Product.asp?Item=N82E16820227213
http://www2.newegg.com/Product/Product.asp?Item=N82E16820145440
http://www2.newegg.com/Product/Product.asp?Item=N82E16820146898
http://www2.newegg.com/Product/Product.asp?Item=N82E16820220006
http://www2.newegg.com/Product/Product.asp?Item=N82E16820231012 (oos for now)
Not sure about my power supply...I think it's generic :S Would it be good enough to overclock with, if I got one of the more expensive memory packs I listed?
Feb 17, 2005
4,300
another stick of 512 kingmax should do the job. you should get a new psu asap. xclio 450 should work just fine.
UsandThem
16,068
7,383
I wouldn't trust a no name cheap power supply. That is a lot of money worth of hardware that could be ruined.
I would also sell the 512 Mb of ram you have and get some Patriot or OCZ memory.
IanE
370
Change the memory to 2x512mb Corsair VS PC3200 for $81 on Newegg.com. Sale ends in about 5 hours!
And definitely get a leading brand PSU... usually ones that come with cases crap out and smell bad... unless it's Antec, I've never had trouble with them.
AgeOfDiscovery
23
@Usandthem, would the OCZ Value VX memory be able to overclock decently on my MB you think, or does my MB suck too much for it? :p
@wafflesandsyrup, is it just me or do the amps seem pretty low on that PS though?
UsandThem
16,068
7,383
You might get somewhat of an overclock out of that ram. Most value ram overclocks a little, but it is not the norm to get a great overclock out of most of it.
You really won't gain too much from overclocking your ram. Your CPU however.......;)
Your system will feel fast enough.
leigh6
3,011
Because you are buying a case with power supply and the power supply seems to be questionable it probably would be better if you boungt an Antec case. At least you get a quality ps with the case.
Just my 2cents.
Leigh
leigh6
3,011
Does Fortron or OCZ make cases too?
No reason to buy a case WITH a power supply if you are replacing the power supply.
Either buy a casw with a good quality power supply (Antec is certainly a choice) or:
Buy a case without a power supply and then choose a power supply
AgeOfDiscovery
23
I wouldn't have individually chosen that case, but it was part of a packaged deal. I got it all for a little over $500 :D @smth, If I can't really overclock my ram that much (unless I bought TCCD, which is too expensive for me), what's the purpose in buying such a costly PS?
smthmlk
493
Stability.
