Memory or Motherboard issue
oxide7
My system setup is as follows.
Mobo - GIGABYTE GA-965P-S3
CPU - Intel C2D E6400
RAM - CORSAIR XMS2 1GB (2 x 512MB) DDR2 800 (PC2 6400)
VGA - EVGA GeForce 8800GTS 640MB
PSU - Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
OS - Windows Vista x86
Thats should be all the relevant info.
The problem I'm having seems to be memory related.
The RAM I'm using from what I understand should run at 5-5-5-12* or 15* at1.9v* or 2.1v*; (* I'm being told either of these number I'm not sure which is correct)
CPU-Z is telling me the ram is running at 5-8-8-24 with command rate at 2T. im guessing stock voltage of 1.8 too.
If i start messing with any of the timing in the bios, all i get are problems. I get random shutdowns, a quick blue screen before a shutdown i noticed something about memory, and sometimes it would do the post beep noise, go through everything and freeze before it got to windows. it even froze on me in the bios at one time. So i set it all back to auto and everything is stable.
I've tried setting it to 5-5-5-12, 5-5-5-15, both of those with voltages of 1.9 and 2.1. and the results tend to be the same.
I could just keep letting the bios run it at whatever works, but I'm guessing im taking a hit here. Although CPU-Z does say that the frequency is at 525 with 5-8-8-24, 2T. and if thats accurate then thats a great inst it? cus it should be 400 normally...yes?
Anyway I'm open to any suggestions ideas or even any technical info you can give me. I'm not new to computers but I am a bit of a novice to over-clocking and definitely new to memory timing. Thanks in advance.
