- Nov 22, 2012
- 1,630
- 810
- 136
I have a GA-Z170X-UD3 motherboard, and Kingston HyperX Fury 2666MHz 32GB (4x8GB) RAM. The memory kit is listed as approved in the mobo documentation.
My problem is that the motherboard won't boot with all 4 sticks. Or, well, it boots but the screen never turns on and it reboots/loops after 30+ secs. The BIOS led display on the mobo shows a ton of codes but it ends up at 55 (which is supposed to be memory issue) before rebooting.
So, I've tried all combinations of sticks. Any two sticks will work, in any two slots. Meaning, stick 1 and 3 in slot 0 and 2, stick 2 and 4 in slot 1 and 3, and so on. You get the idea. In my head this would indicate that the memory should be fine? I've also clocked the memory both at XMP 2666 and at 2133. No difference. I also tried overvolting it.
Any ideas? I've had it this way since buying the rig late last year, so I've also gone through all the BIOS updates in that time.
Edit: It did actually boot up with all sticks a few times in the beginning, completely at random. Which is why I've held out for so long. I couldn't find a pattern to it then and since then I have not gotten it to work.
