- Nov 30, 2005
- 15
- 0
- 0
Hi,
Guys I am looking to bye a 2 GiG memory kit 2 x 1gig memory
PC 3200 DDR 400
I would like to get 2-2-2-2 memory if they make it in 1gig moduls. Am looking for good over clocking memory Die c or TCCD memory if possiable.
Read a few artices here am confussed a little about picking out good kit.
What are some good kits
Below is what I found on Newegg. Any of thouse better then the rest.
Computer Hardware > Memory & Flash Memory > Memory - System > type : 184-Pin DDR SDRAM > capacity : 2GB (2 x 1GB) > cas latency : 2
1-10 of 10 results. 10 Kits to chose from
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model F1-3200PHU2-2GBZX - Retail
Cas Latency: 2
Heat Spreader: Yes
Manufacturer Warranty: Lifetime
Timing: 2-3-2-5
Voltage: 2.6V-2.75V
Model #: F1-3200PHU2-2GBZX
Item #: N82E16820231032
In Stock
$5.00 Instant Savings
$4.81 Three Day Shipping
[74 reviews]
Move To Wish List
Original Price: $199.00
Instant Savings: -$5.00
$194.00
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Platinum System Memory Model OCZ4002048ELDCPE-K - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
Model #: OCZ4002048ELDCPE-K
Item #: N82E16820227210
In Stock
$40.00 Mail-In Rebate
Free Three Day Shipping
[343 reviews]
Move To Wish List
$227.44
($187.44 after $40.00 Mail-In Rebate
OCZ Titanium 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model OCZ4002048ELDCTE-K - Retail
Cas Latency: 2
Features: Titanium Mirrored Copper Heatspreader
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
Model #: OCZ4002048ELDCTE-K
Item #: N82E16820227056
In Stock
$30.00 Mail-In Rebate
[16 reviews]
Move To Wish List
$273.44
($243.44 after $30.00 Mail-In Rebate)
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2 - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
Model #: Twinx2048-3200c2
Item #: N82E16820145574
In Stock
[51 reviews]
Move To Wish List
$221.00
($181.00 after $40.00 Mail-In Rebate)
View Pic Patriot 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model PDC2G3200LLK - Retail
Cas Latency: 2
Features: Engineered with the best quality components, the Patriot Dual Channel (DC) line is the ultimate solution for the extreme gamers and performance enthusiasts. It is compatible with Intel 865, 875, nVIDIA nForce2, nForce3, nForce4 and VIA K8T800 chipsets. They are 100% tested, guaranteed to work at 400MHz at 2-3-2-5 timing.
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
Model #: PDC2G3200LLK
Item #: N82E16820220040
In Stock
[37 reviews]
Move To Wish List
$235.00
($195.00 after $40.00 Mail-In Rebate
G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model F1-3200BIU2-2GBHX - Retail
Cas Latency: 2
Features: 6 Layers PCB
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.5V-2.7V
Model #: F1-3200BIU2-2GBHX
Item #: N82E16820231034
In Stock
[6 reviews]
Move To Wish List
$245.00
gigaram mach1000 series 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model GR1DD8T-K2GB/400/2.0 - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
Model #: GR1DD8T-K2GB/400/2.0
Item #: N82E16820221135
In Stock
[5 reviews]
Move To Wish List
$222.00
OCZ Gold GX 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model OCZ4002048ELGEGXT-K - Retail
Cas Latency: 2
Heat Spreader: Gold XTC
Timing: 2-3-3-8
Voltage: 2.8V
Model #: OCZ4002048ELGEGXT-K
Item #: N82E16820227063
In Stock
[1 reviews]
Move To Wish List
$229.93
($189.93 after $40.00 Mail-In Rebate)
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINXP2048-3200C2 - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
Model #: TWINXP2048-3200C2
Item #: N82E16820145019
In Stock
Move To Wish List
$299.00
Patriot 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 433 (PC 3500) Unbuffered Dual Channel Kit System Memory Model PDC2G3500LLK - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Model #: PDC2G3500LLK
Item #: N82E16820220082
Out Of Stock
Move To Wish List
$242.50
Twinx2048-3200c2 Memory - SystemView Pic CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2 - Retail
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
In Stock
[51 reviews]
Move To Wish List
$221.00
Thanks,
Darin
PC 3200 DDR 400
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V-2.75V
In Stock
[74 reviews]
Move To Wish List
$194.00
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
In Stock
[343 reviews]
Move To Wish List
$227.44
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
In Stock
[16 reviews]
Move To Wish List
$273.44
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
In Stock
[51 reviews]
Move To Wish List
$221.00
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
In Stock
[37 reviews]
Move To Wish List
$235.00
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.5V-2.7V
In Stock
[6 reviews]
Move To Wish List
$245.00
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Voltage: 2.6V
In Stock
[5 reviews]
Move To Wish List
$222.00
Cas Latency: 2
Timing: 2-3-3-8
Voltage: 2.8V
In Stock
[1 reviews]
Move To Wish List
$229.93
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
In Stock
Move To Wish List
$299.00
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-2-5
Out Of Stock
Move To Wish List
$242.50
Cas Latency: 2
Heat Spreader: Yes
Timing: 2-3-3-6
Voltage: 2.75V
In Stock
[51 reviews]
Move To Wish List
$221.00
Thanks,
Darin
