Originally posted by: ts3433
Yeah, it's called a divider. Running asynchronously like this doesn't kill performance on A64s as it does on P4s, so get value RAM.
theoriginalamdoverclocker: Was that comment directed at my recommendation? Yes, 2-2-2-5 stuff will be the best RAM for that system, but as is shown here and other places, it's simply not worth the price delta.
Originally posted by: sxr7171
I just got in on the deal at Outpost - $99 for 2 x 512MB Kingston Value RAM. I hope it lets me hit a decent OC. Nobody has ever really explained why you can't get a modest OC with Value RAM. Isn't there a way to OC the CPU without OCing the RAM?
Originally posted by: amheck
So if Value Ram is ok for these setups, then the HyperX should be even better, right? I'm beginning to piece together an A64 system, but to be honest with you, I always wanted memory with the heat speaders on them. I think I'm going to spend the extra couple bucks on the memory with heat spreaders. Outpost has 2x512 for $140 after $20 MIR.
