alrighty... This problem has been haunting me for 2 days straight...
I installed Counter-strike:Source on friday... and played for a bit and everything was fine. So, I got some advice to try the omega drivers for my Leadtek Nvidia 5700... so I did... seemed the same to me...
Then I got some advice on OCing my AMD 2800... so I went into the bios... and changed the multipliers... to 200 x 11 .... This locked up the comp (because my 2800 happens to be locked to OCing).... and then I had to get the bios back to default... so I took off the bios jumper and put it back on... (I had done this previously with no prob...)...
by default it sets my proc to run at like 1250mhz.. so I changed it back to the 2800 default of 166 x 12.5/13 .... The comp works fine... starts runs like normal.... EXCEPT when I try to play ANY GAME.
This lead me to try MANY MANY MANY different vid card drivers... using driver cleaner many times... going in and trying to manually delete some registry entries to do with nvidia ...... So... after 10 hours yesterday... 6 hours today..... I am stuck.
I have NEVER had a problem before this... my card ran on leadtek's drivers fantastically. I have been playing city of heroes with this setup for 5 months... also tons of demos.... counter-strike/dod and such.
NOW... I crash to desktop in EVERY GAME.... from 3 secs to 5 minutes of play.. I CRASH ..
MY ram is good... tested it... I am leaning towards there being something wrong with my registry/bios....
Here are my specs....
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: MSI
System Model: MS-6712
BIOS: Version 07.00T
Processor: AMD Athlon(tm) XP 2800+, ~2.1GHz
Memory: 768MB RAM
Page File: 138MB used, 971MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
Card name: NVIDIA GeForce FX 5700 (Omega Q 1.5672a)
Manufacturer: NVIDIA (Omega Q 1.5672a)
Chip type: GeForce FX 5700
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0342&SUBSYS_2982107D&REV_A1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (100Hz)
Monitor: Gateway VX920
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.5672 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/24/2004 06:04:00, 4274560 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 3/24/2004 06:04:00, 1895648 bytes
Device Identifier: {D7B71E3E-4002-11CF-E565-880900C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0342
SubSys ID: 0x2982107D
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Description: SB Live! Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80321102&REV_07
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: emu10k1m.sys
Driver Version: 5.12.0001.3300 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 12:19:26, 283904 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 100000
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Name: VIA CPU to AGP2.0/AGP3.0 Controller
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 04:42:00, 27904 bytes
Name: VIA Standard Host Bridge
Device ID: PCI\VEN_1106&DEV_3189&SUBSYS_00000000&REV_80\3&61AAA01&0&00
Driver: n/a
Name: VIA Standard PCI to ISA Bridge
Device ID: PCI\VEN_1106&DEV_3177&SUBSYS_00000000&REV_00\3&61AAA01&0&88
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_71201462&REV_82\3&61AAA01&0&83
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:52, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:50, 51968 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1106 (English), 8/29/2002 03:40:56, 5120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 15:36:34, 67072 bytes
Name: VIA Compatable Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_712C1462&REV_74\3&61AAA01&0&90
Driver: C:\WINDOWS\System32\DRIVERS\fetnd5.sys, 2.66.0000.0290 (English), 8/17/2001 05:13:08, 27165 bytes
Name: Realtek AC'97 Audio for VIA (R) Audio Controller
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_71201462&REV_50\3&61AAA01&0&8D
Driver: n/a
BIG THANKS TO ANYONE WHO CAN HELP ME
Then I started getting crash to desktop errors.
Memory: 768MB RAM
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0342
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Driver: n/a
Driver: n/a
