Hi I am looking into putting together a computer and eventually overclocking it.
Looking at all the information about CPU speeds and memory speeds, I just have one question maybe someone can answer.
DDR2-800 has a memory clock of 200 MHz and an I/O Bus clock of 400 MHz.
Using this in combination with an e8400, multiplier 9x, FSB 333 MHz:
1. Would the default setup slow the memory down to 333 MHz?
Or...
2. Is the memory already too slow at 200 MHz?
In the event of #1, would the memory divider then be 1:1 with a FSB of 333 and memory at 333? Could I then overclock the FSB slowly, along with the memory trying to get close to 400 MHz FSB to match the rated DDR2-800?
If the memory wont go above 400 MHz, but the CPU will, would it be worth it to change the memory divider to something other than 1:1?
Say 450 MHz CPU and 400 MHz memory at 1:125? Is that even possible? What are the increments you can change the memory divider in?
If anyone could answer these questions I would appreciate it, as the answers will affect my decisions for purchases of parts.
Or...
