- Dec 5, 2004
- 3,163
- 0
- 0
Hi,
Ive been reading these forums for a few months, but this is my first time posting (i havn't really had anything to post about before
In January I plan on upgrading my rig to:
A64 3200 (939)
Thermalright xp-90 (AS5)
Nf4 non-sli mobo (if i can afford it)
6800 gt
OCZ 470 or 520 watt power supply
PC 3200 ram (see below)
The rest of the parts i am going to reuse from my current comp, which includes:
80 gig Maxtor HD (pata)
20 gig Maxtor HD (pata)
Antec Plus660AMG Case
No name CD-RW drive.
Floppy drive.
If see any problems with this setup please let me know.
I have built a few comps before, so i pretty much know what i'm doing. However, I plan on OCing this comp, which i havn't done before, and i had a few questions about that.
First, im not really sure what ram i should get. I want to try and hit a FSB of 240-260 (2400-2600GHZ) if my proc can handle it. The Crucial Ballistix memory seems to get the best timings in this range and its what i'm leaning toward. However, when ever someone asks what ram they should, everyone seems to responds with the OCZ PC3200 Platinum Rev. 2. Im probably missing something, but i dont why this would be recomended over the Ballistix, seeing as they cost about the same.
My second question was how you would recomend I go about overclocking. Should i lower the multiplier first, push the ram to my desired FSB, then raise the multplier up (1X at a time). Or should i lower the memory ratio, try and get the CPU to 2600ghz, if it will, then raise the multplier back up. Or should i do one, then the other, and try and find a FSB that is as close the both part's max as possible. Or is there some other way thats easier/quicker?
I apologize if either of these topics has been covered before, but i havn't seen anything about them.
Thanks in advanced for the help.
A64 3200 (939)
6800 gt
Floppy drive.
