- Jun 30, 2004
- 16,627
- 2,024
- 126
Member "Nastymatt" had sent me a PM expressing frustration with his 780i board and the E8400 processor. He cannot reset his BIOS back to the stable OC settings.
NOW . . . . I . . . . have done the same with my 680i chipset and latest August 08 BIOS revision.
I reset the BIOS back to 3.0 Ghz for the E8400 to run some preliminary tests for resolving a conflict between VISTA64 screensaver and PRIME95 Blend Test. It was actually unnecessary, because the memory settings at "3.0 Ghz" would be the same as for 3.6 Ghz. Only the divider would change.
NOW, I wanted to reset to the 3.6 GHZ values.
EVERY $*&@# TIME I change the FSB/DDR Configuration from "Auto" to "Unlinked" and "Save Changes and Exit" -- it boots up as "3.0 Ghz," whereupon re-entering BIOS Setup shows "FSB/DDR Configuration" set to AUTO.
I did a CLR CMOS (carefully), hooked everything back up, entered BIOS and carefully chose the right settings again, but "NOOOOO . . . . CI-GARRRR!!"
I'm thinking that at worst, I can pull the PLCC BIOS chip, replace it with a spare, re-flash to the latest BIOS, and "go again." But first, I'll CLR CMOS and re-flash the BIOS with the current PLCC chip.
ANY SUGGESTIONS??????
[I almost wanna scream!!]
