Get away! 😛 MW3 is too easy. I can plow through MW3 on High difficulty with zero lancemates (other than the missions where they join me from elsewhere), including the endgame. MW4 Mercs on Elite difficulty is a challenge even with seven lancemates in the best 'mechs C-bills can buy. Try that Griffon Base mission :Q Fortunately, if you are lucky you will be assisted by The AC5 Turret That The Enemies Dare Not Fire Upon For Some Reason 😀Originally posted by: johnnqq
it runs. it jsut freezes though. mw4 sucks compared to 3.
Read your XP Pro license agreement, you're entitled to downgrade if you like 🙂Originally posted by: johnnqq
doesn't work without the patch. yea i have pro 🙂 i can't downgrade to 2000...
It would look almost as good as it does on a 6600GT with an A64, actually. I used a 1GHz Duron instead of a P3, and a slower GF2 GTS-V(alue), but close enough. Radeon 7500 doesn't do too bad either. I wish they'd do a MW5 with, like, the FarCry engine or something :Q dude!(how do you think mw4 would look on a p3 933 and a geforce 2 gts?)
Build a custom Annihilator with max armor, minimum engine, and all the LRMs and heatsinks you can possibly cram onto it. Stay near the shuttle, wait for one of those Clan fools to come within range, and start unloading salvos of LRMs on them :evil: Use your coolant flushes to bring the temps down as needed. You'll take some PPC strikes but you'll easily outlast them if you take the standoff approach.i have 384... how did u beat mw3 5vs1 on hardest settings?
