Symptons:
My bike has two brake/rear light bulbs that work together. For some reason, the left light keeps blowing. The right one is fine. They're connected in parrallel.
Secondly, the bike goes through stages where the fuse blows. It'll start ok and the lights will run, but I *think* when I apply the brake, the fuse pops (so annoying...). A couple of weeks ago I replaced the blown lightbulb and had a look around that area of the loom but all seemed fine. The left rear light lasted a week and only today did the fuse blow.
So I'm a little perplexed. At first I thought it could be the bulb working loose and touching the two contacts making a short, but the bulb was securely in place, and if it was shorting, the other bulb wouldn't work.
I've just picked up a multimeter/circuit tester which I'm going to mess around with this weekend, but any ideas/suggestions on the procedure to find an electrical fault would be of great use.
Cheers.
Cheers.
