- Jan 2, 2006
- 10,455
- 35
- 91
I've got a propeller cage for my paramotor:
I need to break it down into a more compact form for airline travel. I want to cut the aluminum tubes at the red lines, effectively halving the width, install smaller diameter metal tubes *inside* of the existing tubes, and drill holes so they can be taken apart but still joined back together again with locking pins.
The problem is with the diagonal tube circled:
All the other tubes can be pushed back together easily because they're all parallel, but what do I do about the diagonal bit? It seems the only way to join this would be to install a metal sleeve / tube *outside* of the existing tube.
Does this appear to be the most straightforward method?
