[/b]Background info:[/b]
i have an '85 jaguar xj6. I just got the alarm installed and things were working fine. The car shop that installed my alarm removed my radio and threw the actual radio on the front seat and left the face plate on the bare metal floor in the back, as well as failing to install the lights IN SPITE OF the fact that my car is missing a door panel on the passenger side (b/c i was fixing a lock) and the fact that i took out the rear bench seats.
Problem:
Anyways, i was putting my radio back in and wiring it into the fuse box when i accidentally grounded out the wires past my fuse box. NOW...my car won't turn...not even a noise from my starter.
What i need:
I called the car shop looking for ideas. They told me it sounded probable to be the fault of a blown ignition fuse. I can't seem to find that and in the two fuse boxes that i have, all fuses have perfect continuity. I asked if the starter kill from the alarm was faulting my start, but there is no fuse and he said the alarm is not at fault seeing as it still activates and my remote start does a perfect emulation of a key in the ignition.
So....how do i bypass my ignition (even though i have a key) to tell if the ignition IS in fact the problem? I found my distributor and was going to bridge the two terminals, but after finding it, realized it was near impossible to pull off. BTW...my dad says bridging out the distributor is NOT the correct way to hotwire a car.
help
-=bmacd=-
Problem:
What i need:
help
-=bmacd=-
