Mechanical engineers... I need some help
Mrvile
14,066
Hey all,
For a project I'm working on for school I basically need to come up with a mechanism that can move a somewhat heavy load (up to 50lbs) up and down on a rail rather effortlessly, and stay in place at any point along the rail, without breaking the bank. I looked briefly into balanced tension springs, like on articulating lamps, and their variations (hydraulics, pneumatics). I also noticed that many hardware stores sell pneumatic door openers for pretty cheap, so I figured I could use those.
Can anyone school me on how I would actually go about getting this to work correctly, or why it wouldn't work at all? Are there any alternatives?
Thanks!
PottedMeat
12,363
475
I'm not a ME but could you use ACME screws on a linear slide?
You can get 3' and 6' lengths of screw threaded rod cheap. Usually they're used for mill/lathe repairs.
When you say 'up and down' do you mean vertically or horizontally or both?
What's the travel distance?
What's the speed required?
Sukhoi
15,350
Yeah need more info on layout, but a power screw would be a pretty good idea.
Mrvile
14,066
Sorry, more details.
The motion is just vertical. Distance travel should be about 3 ft or so. Speed should be pretty rapid, be able to cover the 3 ft within a few seconds.
Mrvile
14,066
Power screw would be too slow, and I prefer not to have any electronics involved. I want the motion to be possible through just lifting the weight with arms/hands.
Mrvile
14,066
One last note. Some examples I was looking at are things like car trunk doors, manual garage doors, balanced arm articulating lamps, etc. That's the type of motion I'm looking for.
Thanks!
PottedMeat
12,363
475
is the load variable - are you being asked to haul a bunch of different stuff? Maybe pulleys + counterweight would be easy.
Mrvile
14,066
Load should be pretty constant. I said "up to 50lbs" because I'm not sure exactly how heavy it will be yet.
Pulleys + counterweight seems like a good idea, I just figured those pneumatic door things are simpler and more compact as the mechanism is packaged into a relatively small tube.
Bignate603
13,897
Those gas springs in doors change the force they provide depending on the distance they are extended while a pulley/counterweight system would maintain the same over the complete range of travel. As long as the load would only vary through a small range and the direction remains constant it's a very good way of doing it.
Additionally, it could be difficult to find the gas spring with the amount of force that you need. For a pulley/counterweight you just change the weight until it is the amount of assistance you need. It will be cheap and easy to get it to work perfectly.
As for it stopping right where you want it to, you can use almost anything as long as the load is light. If the load is well balanced against the counter weight you could even introduce a small amount of friction into the system that is enough to make it stick at whatever point you want.
LordMorpheus
6,871
if the load is known and doesn't change, a counterweight system will be good.
Even if the load changes some, if you counterweight it based on the expected load, with enough damping that it won't run away from you if it's underloaded, it should be fine.
Modelworks
16,240
7
Problem with counterweight is the unknown load . One thing you could try really easily is elastic bands. Get some rubber bands and play around with it. Some type of elastic might work well with varying weights because you could use multiple strengths depending on the need. One above and one below gives a nice counterweight like performance without the weight.
Triumph
14
Without any further helpful descriptions of the problem statement, counterweights are the clear answer.
Bignate603
13,897
He said the load wouldn't vary much. Elastic bands may not work well for the same reason that gas springs could be difficult, the force they provide varies greatly depending on the amount of extension. You would get a great deal of force when the band is stretched farther and far less when its more relaxed.
lxskllr
60,203
10,663
You could use some kind of scheme when forward momentum stops, the load rocks back slightly from vertical, and engages a wedge that pinches the rail. A lot of that would depend on the exact setup though.
iGas
6,240
Counter weight pulleys or a fulcrum with counter weight (or sliding counter weight).
