MCE ERROR Help
revolutn
104
Any help greatly appreciated.
Per M$ I can use Intel Pentium Pro Devel Manual Vol 3: O.S.'s to decode, but can't fine online so far.
All research I've done to date indicates either an internal CPU or RAM problem, ram seems to check out OK.
Will List system specs below, error code is as follows:
MACHINE CHECK EXCEPTION ERORR
STOP: 0x0000009c. 0X00000000, 0x08054D370, 0XB2000000, 0X1020080F
P4 2.4ghz (Northwood core) stock settings 18x133 Family F Model 2 Stepping 7 Revision C1
OCZ DDR2 512 MB (OCZ400512V3)
Biostar U8668D V7.A (w/ latest public bios from www.biostar.com.tw)
M$ XP Home (wsp2 and all latest updates)
All components are the onboard integrated ( NIC, Audio, VGA )
Suspect either a CPU TLB or Cache problem but would appreciate any thoughts on how to verify and or how to decode the error code above to isolate the faulty component.
Issue ONLY shows up intermitently while streaming online video content.
Some basic games play fine, not a gamming rig so no hardcore games played, just things like Hoyle's Cards etc and all play fine w/o BSOD.
TIA,
Rev
