MBP not detecting external monitor
Wow thats cool to know... Didn't know you could update the firmware on those adapters...
It's because displayport is digital only so there are DACs in those adaptors to convert the signal.
The Monoprice ones are $18 and change BTW.
It looks like its fine, but I would ask the seller if that's the firmware update that you need. Do you have any other display you can use to test it with?
We had to use the firmware update to be able to connect our Xserve with the KVM.
I bought the monoprice one and i have the
This firmware update addresses possible intermittent flickering
problem sooo im going to try to use the apple update on it
also yours and the monoprice looks exactly the same. So i wouldnt be surprised if they where the same
i keep getting "the updater could not find a mini display port to vga adapter to update"
im thinking bad mini adapter? the MBP is less then a week old...
