Running MBM4, the temperature ratings (I have not installed any other temp. sensors, as this is a work computer) are reading:
Sensor 1: 25 degrees C
Sensor 2: 38 degrees C
The ambient room temperature is currently 78.3 degrees Farenheit (25.7 degrees C). The case is open, and is an Enlight 7237.
Sensor 2 appears to jump back and forth between 37 and 48, though I don't know why; every time it jumps to 48, it will jump right back to 38 (I have felt the CPU, and it does not seem to be hot at all).
Should I be concerned about these temperatures at all?
Rob
Rob
