I cant seem to config MBM 5, partly because it doesn't have any asus a8n series mobos. Is there any other way for me to config it, I kinda don't get how to use it either. I just need to check voltages on my actuall components, and not just rails.
i don't know any way to check voltages on "individual components"....i'm pretty sure there is no software program that will do that, MBM just monitors rail voltage. it sounds like a multimeter might be what your looking for...
