Greetings,
looking at https://www.asus.com/us/Motherboards/PRIME-B450M-A-CSM/specifications/ for example, it lists the following under supported memory:
Thanks,
Dagg.
I see that for speed of 3200 there is a O.C. after it, what does this means?AMD Ryzen™ 2nd Generation/ Ryzen™ with Radeon™ Vega Graphics/ Ryzen™ 1st Generation Processors
4 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
ECC Memory (ECC mode) support varies by CPU.
** Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
Thanks,
Dagg.
