AddictiveGamer
Hi guys,
My computer doesn't recognize the hard drives anymore. Below is my computer setup:
MSI K8N Neo2 Plat
AMD 3500+
1 IDE HD (OS)
1 IDE HD (Data)
2 SATA HDs (Data)
Here is my problem:
The computer worked perfectly fine with 4 hard drives for about a year. A month ago, whenever it powered up, it did a diskscan and sometimes hung. I removed the hard drives one-by-one and found that if I disconnected the data IDE hard drive, the system booted up and worked fine. So I left the system with one IDE drive disconnected.
A week ago, the computer sometimes failed to recognize all drives (even the main OS drive). Sometimes, it recognized all 3 drives but hung at scandisk. So, I used the same trick again, but this time, I have to remove BOTH SATA drives for the system to bootup. Right now, the system is working, but with only one IDE drive (main OS drive) connected.
I scanned virus, but found nothing. I upgraded the BIOS, but it still doesn't work. Are all 3 drives dead? Is there anything I can do to fix this? Thank you in advance!
Regards,
MSI K8N Neo2 Plat
AMD 3500+
1 IDE HD (OS)
1 IDE HD (Data)
2 SATA HDs (Data)
Here is my problem:
Regards,
