MB CPU Fan Connector
FrozenPixel
29
Does it matter if no fan is connected to the assigned cpu fan connector on the MB? I just picked the Asus Maximus Formula and the Thermalright Ultra-120 Extreme cooler and added the Scythe SFLEX 120mm fan to keep it cool but going through a mock install I noticed the CPU fan connector on the board is 4 prong but the fan is a 3 prong. Is it ok just to connect it to one of the optional 3 prong fan connectors?
Thanks
zagood
4,102
You can plug the 3-pin fan into a 4-pin motherboard header. You'll see a plastic guide on the header that will only allow you to connect it the right way.
If you plug it into one of the optional headers, make sure you disable any CPU fan speed monitoring settings in the BIOS.
-z
FrozenPixel
29
Oh I noticed the offset slot but thought it was only for the 4 pin plug. Thank you very much zagood for clearing that up.
