Mazda Miata with Corvette engine and Camaro transmission.
Shawn
The combo:
98 vette engine with moded oil pan with a 2004 ls6 block
ported stock 98 heads with comp 918 springs and ti-retainers
7.4" harden push rods with Harlansharp 1.7 rockers
Moded valve covers to accept the rockers
Ported stock throttle body
gapless piston rings and ported oil pump
Double roller T-chain and Arp rod bolts
tr224/224 cam on a 114
99 camaro Pcm with custom wire harness
A racing miata radiator 2 1/16" thick aluminum
a new 2002 camaro T-56 trans with Zo6 clucth assy.
A 11lb fly wheel with a f-body aluminum drive shaft which is 28 1/2" long
a ford t-bird posi rear 3.27:1
15 pound rims that are 16X7's 225/40r16's front 245/45r16's rear Tires
Race beat race springs front and rear with Agx shocks
Custom sub frame...trans cross member and moded Powerplant frame.
And lots of other little things....which add up
Thread
Pics
Neat. I've seen a couple Miatas up here that had 302 (5.0L) Mustang motors in them...they were pretty crazy.
Originally posted by: Shawn
The combo:
Thread
Pics
Overclock it.
Originally posted by: MaxFusion16
how much is the weight increased and what's the weight balance?
I don't know. But I'm sure it ruined the 50:50 weight distribution.
Shouldn't - the chevy engine is supposed to be very small - lighter than mmany smaller engines.
It's a small, light engine, for what it is. It's not smaller, nor lighter, than the tiny 4 cylinder that miata's usually come with.
I believe the soda can more than makes up for it's added weight in the power it produces
We weren't discussing power, we were discussing weight.
Well - according to this link, the weight difference between the engines is less than 100lbs. I woudn't say that'd totally ruin the handling.
http://forums.motortrend.com/ubbthreads...=&Number=6463&page=&view=&sb=5&o=&vc=1
