Mazda 3 clanging in rear of car
Status
Not open for further replies.
jwir3
I have a 2007 Mazda 3 sedan with ~100,000 miles on it (it's the 2.0L version). Last October, I noticed a significant clanging noise that was coming from the rear of the vehicle whenever I went over some small bump. I was told I had a rear spring that was broken, and had both of the rear springs replaced.
Recently, I have noticed a similar clanging sound coming from the back of the vehicle. I took it to a couple of mechanics, and they said that the rear sway bar links needed to be replaced, and showed me how they were loose and had some give in them.
I performed this replacement myself last weekend, and I've noticed that, for the most part, the clanging has gone away. Unfortunately, it hasn't gone away completely. When I go over a major bump, like a speed bump or other major incline with a sharp drop, I still notice a sound like I noticed before.
It's not as significant as I previously noticed, but I'm kind of at the end of what I know in terms of troubleshooting. If possible, I'd like to fix this myself, because I am trying to learn more about how my vehicle works. I don't know how to go about diagnosing the problem, though.
Could it be that I installed the rear sway bar links incorrectly? I've looked at them, and they don't have the give the old ones had, but the one on the passenger side looks like it's at somewhat of an odd angle... this could be my imagination (here's a picture of the sway bar link install: http://imgur.com/vecr2 ) One thing I may have done incorrectly is that I didn't actually remove the sway bar to install the links, I removed the old links and then flexed the new links into position with the sway bar in place. In hindsight, this was probably not a great idea. :| The nuts are nylon lock-nuts, so I'm hesitant to remove them and try to install it again, since this might screw up the nuts.
One individual advised me that it might be useful to check the struts to make sure they are good. I visibly inspected them, and see no oil or leakage of any kind. When I press down on the bumper 5-6 times and get a good bounce going, then release, it takes less than 1 bounce for it to stop. My thinking is it isn't the struts, but I could be wrong.
I'd really appreciate some pointers as to what I should look for and how I might be able to fix this problem.
Something definitely does look off with the sway bar endlink on the right side. I would redo that, correctly, and see if it fixes it.
At 100k miles, since you're interested in doing it yourself, you might consider replacing all of the bushing in the rear suspension (one side at a time!).
These types of things can be difficult to diagnose online. You might try using a solid metal bar pressed up against metal suspension pieces as a makeshift stethoscope... Have someone bounce the trunk up and down while you try to find the source. Don't get squished.
It almost looks like the nylock nut is cross threaded on the right side end link. If that's the case, it will definitely cause banging noises over bumps.
Also, when installing the sway bar links, would it be better to remove both of them, remove the sway bar, attach the links, then re-attach the sway bar, or can I simply remove the right side sway bar link and re-install it by itself?
Thanks for your help, by the way, I really appreciate your guidance.
This thread is a turbofail, and a prime example of why you shouldn't ask for mechanical advice on the Internet, especially on a computer forum.
If you have nothing to add but this then stay out of the thread...
Thread crapping...
AT Moderator
Bartman39
That right nylock-if it felt good going on then I don't believe you have a problem.
The angle of the picture may just be what makes it look messed up.
There are 2 other bushings on the inner part of that sway bar.Also there are quite a few other bushings under there.
You either pick away at replacing parts or find someone that really knows how to diagnois suspension noise.
@nicolaskl: This forum is very good at pointing people in the right direction.
Yes, you need to research/verify the information-not everyone is correct.
I find in general the information can be time/money saving.
It’s difficult to tell if the right side link is cross threaded or not. Obviously you should know if the nut when on easy or was difficult screwing on.
Did you replace the bushings on the sway bar also?
There happens to be a great YouTube video of how to do this repair.
http://www.youtube.com/watch?v=IRlO_0UMQJo
How about you pick out a post and debate it, rather than be a passive aggressive little <s>bitch</s> brat sitting in the corner whining
I said cross threaded, but I'm basing this off of the angle of the bolt and stud with the swaybar. In the pic it looks like it's at a very steep angle rather than flat against the bushing.
No idea, each setup is different.. As Raiz posted, you might try a youtube vid or a post on a specific mazda forum.
The problem you stated sounds like the rear sway bar. I would suggest studying the YouTube video and follow their instructions on replacing the two bushings. If the bushings are worn, you will get a rattle noise when going over most any size bump in the road. This actually is a pretty common problem with this car. So much of a problem that there are numerous aftermarket heavy duty sway bars available.
Changing bushings (mostly) is to eliminate worn out parts and noises.
Changing sway bars changes the ride.
Status
