This was justa Idea I had dont no if it would work.
Find a old small Freezer, I have some very small ones for sale kinda cheap think $150 new.
Then cut 2 holes big enough for the Tubing and Gromet to seal the Freezer.
then place the pupm and radiator whith a Fan in the Freezer.
Then hook up everything else the way you are supose to.
keep the Freezer at max cooling and make sure it is one the auto Defrost.
Almost forgot use a antifreeze liquid .
Do ya see any probelems with this and if not think it would help to make your CPU cooler?
