Today I relocated the right speaker (the one with the volume, etc controls), Unplugged it and plugged it back into the sub without disconnecting the power.
Now those controls don't work. The speakers still play, the volume can be controlled by windows still. When I hit any of the buttons on the speaker the LED goes from amber to green indicating the button press was detected but there is no response in windows.
I tired them on my laptop to eliminate the possibility that it was a driver issue...same symptoms.
The USB interface must work since they still play...no bent pins on the din plug for the right channel. Everything still works excpt the mute, bass, volume controls.
Any ideas? I've left them unplugged...hopfully letting the capacitors will fully drain.
I'll check out the functionality of the analogue side tommorow...just gotta find an 1/8 to an 1/8 connector.
