I own 6 maxtor drives. They seemed to be fast and reliable and a good value.
In the last 3 months, 3 have failed. I'm not sure the exact problem but the symptoms have been anywhere from corrupted data, extreme reduction in performance, and most recently, sudden failure (click of death). I caught the first two early through SMART errors. The last lost me some data, which I'm currently trying to recover.
50% failure rating for me? I'm not liking this...
The worst part is that the recent failure is on the drive I received back from the first RMA! It died within 3 months.
It seems I'm the exception, but anyone else have any problem with DiamondMax drives?
------- update --------
One thing I've just noticed. All the drives which failed were in AMD/VIA PC's... OK, don't think I'm blaming the chipset because that's obviously not true.
I *am* however curious about a few things.
These 2 PC's are 1GHz Tbirds. Each PC had 2 HD's. The cases are pretty small and cramped, and as a result, the temperatures of these systems are high. In contrast, the other PC's are running celeron's and a 800MHz P3 which all generally run alot cooler.
I'm seriously wondering if this was a heat related issue. I'm not an overclocking fiend, all the PC's I use for work run at stock speeds, but these cases are hot inside. Asus probe measures 55C CPU and 40C System. 40C seems pretty hot, and the drives inside are pretty warm to the touch (I'm sure it doesn't help that they are stacked within 1/2 inch of each other. Perhap it's time for me to consider some improved-airflow cases for my computers.
