- Sep 21, 2002
- 101
- 0
- 0
When I partition and format my external Maxtor HD (120GB) connected via 1394/firewire using XP disk manager, the format reaches 100% and then hangs my system. It does this regardless of partiton size.
I then have to reboot, then disk manager says the partition (NTFS) is healthy, but accessing it in explorer brings up a prompt to format it again. The formatting in explorer also hangs my system at 100% completion, identical to disk manager.
I tried using the USB interface and a small partition and it all worked 100%. Does this mean the firewire portion of the drive is faulty, or my PC? I've only used the firewire card for capturing video up until today. My PC only has USB 1.1 so I'd really like to use the firewire option. Device manager says my firewire is Texas Instruments OHCI compatible, default windows drivers 7/1/2001.
Maxtor 5000DV 120GB
WinXP Home, 768MB
Athlon 1800+
PCI firewire card.
Maxtor 5000DV 120GB
WinXP Home, 768MB
Athlon 1800+
PCI firewire card.
