I recently purchased a EIDE 61.4GB maxtor drive and after several attempts to get it to work in my secondary system(see below for specs) I removed the drive to install it into my primary system(see below for specs)After installing the drive as secondary master and booting, my video display on post was corrupt and blinking. I thought I may have bumped the seating of the card when installing the drive so i reseated my agp video card with the same results. Next I removed the drive thinking it was possibly conflicting with something else. I rebooted the machine same response. After all of the video problems, I had the agp card tested in a third machine, which had the same results. Testing the primary machine with a pci video card it posted ok but would not boot past pnp init. Going back to the secondary machine, on bootup the system would not reconize the ide burner that was on the secondary chain. Rebooting a few times the drive showed up when booting, the machine either does not boot, or locks up after a short amount of time. The machine will not load windows, but will boot linux and reports errors while probing the ide bus.
hda: Maxtor 87000D8, ATA DISK drive
hdb: probing with STATUS(0x00) instead of ALTSTATUS(0x50)
hdd: IDE-CD ReWritable-2x2x6, ATAPI CDROM drive
There is no drive for hdb to show up.
I havent had any issues with maxtor drives in the past, but after this I dont think i want another one. I now have 2 motherboards and a geforce video card to replace and possibly more in the primary machine that has yet been fully tested.
Has anyone else had this sort of problem or heard of this?
Thanks for advance for any information.
The maxtor drive was install as secondary slave.
Primary Machine:
Asus p5a K6-2-550 128mb ram
15GB Western Digital ( Primary master )
40x memorex cdrom ( Secondary master )
Guillemot Prophet Geforce agp
Sounblaster32 pci
3com 3c509 pci
Secondary:
FIC PA-2013 v2.0 K6-2-550 64mb ram + latest bios update
7GB maxtor Hd (primary master)
IDE burner ( Secondary master)
S3 Virge 4mb + VooDoo2 8mb
Soundblaster16 ISA
3com 3c509 pci
Primary Machine:
Sounblaster32 pci
3com 3c509 pci
Secondary:
Soundblaster16 ISA
3com 3c509 pci
