Maxtor DiamonMax Plus 7200rpm/ATA 66 + Soyo 6BA+IV....UDMA?
MTDEW
Owners of this hard drive, Do you have a DMA checkbox under sytem properties for this Hard Drive?
I just installed mine & I don,t have the dma checkbox anymore or for my cdrom.
Maybe it has something to do with my ATA66 on my mobo.
I have a Soyo 6ba+IV & I'm using The Highpoint ATA66 ide controllers.
Is no dma checkbox normal?
Or am I just missing something simple here?
Not related to your hard drive but to the Soyo 6BA+IV and Highpoint controllers. I believe that if you are using the ATA66 controllers you have DMA enabled. Windows sees your drive as a SCSI device and the DMA box is not an option. Enjoy.
Thanks, windows does see it as an SCSI device.
I was wondering why there was no option.
Just trying to make sure I set this up right.
Thanks!
Run some benches. If you se anything above 33MB/s, then you're OK. More than likely, DMA is built into the HPT366 drivers.
-SUO, SY-6BA+IV and WD 20GB ATA66
Downloading it now.
I'll run the benchmarks when I get home from work tonite.
Thanks for the link.
