MAXIMUS VI GENE audio vs Xonar DX
MaKiNoTe
Hi all
I'm about to buy a new computer and I want to know your opinion on the audio of the MAXIMUS VI GENE and how it compares to a Xonar DX.
I always had a discrete sound board and I don't want to hear scratching sounds when my hard disks are working.
Thanks all
DaveSimmons
40,730
670
What do you connect to, and what kind of connection?
It's only analog connections that pick up noise from the CPU, etc. -- HDMI and optical digital don't pick up RFI.
MaKiNoTe
I plan to connect an analog stereo cable to the rear line out connector.
I use it to connect to a hi-fi with a pair of good speakers.
DaveSimmons
40,730
670
Does your hi-fi (receiver) have an optical digital input? If yes, then you can use the optical out on any motherboard or sound card without worries about static, hum, etc.
