have just flashed to the 0907 bios and here goes the stories
1. the second ethernet controller does not work, i have enabled it in the bios, windows device manager sees only the first ethernet controller
2. I have manually set the dimm voltage to 1.8v and the led dimm voltage indicator is now red??
3. Under the power bios option, the CPU PLL voltage is reading 3.20 V in red (i have manually set this to the lowest setting)
4. The dimm voltage is reading 0.0 v in the power menu
5. North bridge voltage is 0.00 V in the power menu (i have 8 gb ram so i set it manually to 1.41v)
6. DDR Reference voltage is aslo reading 0.0V
I did have to increase the vcore to 1.2875 to get my Q6700 stable at 333 x 10 with bios 0907, under 0505 i was able to get away with 1.2750 to get it stable at 3.33Ghz
Should i rma the board for possible defective lan 2 and sensor failure
Kevin
Kevin
