I have an AthlonXP 2000+ on an Asus A7V8X. It seems to be running at about 49c CPU and 35c Motherboard. Is that good, or bad? They'er in an Antec SX630II. My AthlonXP 1600+ on a Soyo K7V Dragon Plus! runs a few degrees cooler, so I wasn't sure if I should do something about the new system or not. What is the best temp range to keep an AthlonXP in?
Also, I saw through the FAQ in this forum an AnandTech guide to figuring out if your temps are too high, but it seemed pretty old (sometime in 2001). Are there any current guides to help you sort through which motherboards read temps high and which read them low, etc. ?
Thanks!
-Midi
Thanks!
-Midi
