MAX11L - mini-ITX gaming monster
miahallen
Some of you have seen this around the web. I never posted the build log here, but you can check it out if you like (linked in my sig).
Here are the final pictures 😎
"It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Core i5 750 and 480 GTX....all powered by a 450 watt SFX PSU (very nice).
What kind of overclock were you able to achieve with the H70 cooler and Gigabyte Mini-ITX mainboard?
quad core at 4.2GHz.....480 GTX at 800/1000....more details here:
http://www.techreaction.net/2010/09...%80%93-max11l-featuring-corsair-and-gigabyte/
Miahallen's article said:
After rebuilding the system with the upgraded components, the next order of business was to overclock the CPU and find out what type of speeds I would be able to extract out of it. The process left me wanting. On the one hand, the H70 cooler was doing an extraordinary job keeping the quad core CPU very cool. Even pushing 1.4V and over 4GHz the cores were barely breaking 70 degrees Celsius while running IntelBurnTest.
On the other hand (and I had been forewarned) was the motherboard’s over current protection (OCP) circuit, which was preventing me from giving the CPU anymore more voltage than that. OCP is a protection mechanism built into the motherboard to prevent damage to the power circuits due to excessive current. Therefore, my “stable” overclock on the CPU was limited to about 4GHz as seen on page 5.
The good news is that I only put minimal weight in stress testing, and all my benchmarks ran stable at 4.2GHz with a bit higher voltages. This is due to the fact that gaming does not put the load, or require the current, that stress testing does. So, for all testing shown, the i5 750 CPU used was run at 4.2GHz.
That is a great overclock.
In the Anandtech Gigabyte Mini-ITX review the author mentioned clearance problems with the Corsair H50--->http://www.anandtech.com/show/3769/reviewed-gigabyte-h55nusb3-miniitx-done-the-gigabyte-way. Did corsair change the base on the H70 to accommodate more ITX boards? (I haven't looked this up yet)
